system-config > comm-monitor
The comm-monitor subelement configures the communication monitor/Palladion Mediation engine.
Parameters
- state
- The state of the Communication Monitor feature.
- sbc-grp-id
- Group ID in the Palladion Mediation engine.
- tls-profile
- tls-profile to use for connection to mediation engines for TLS Connections.
- qos-enable
- Enable/disable sending of QoS information to the mediation engine.
- interim-qos-update
- Enable/disable sending of periodic QoS update information for the duration of a call.
- monitor-collector
- Enters the monitor-collector subelement to configure IP parameters of the Palladion Mediation engines.
Path
comm-monitor is a subelement under the system-config element. The full path from the topmost ACLI prompt is: .
