system-config > comm-monitor > monitor-collector
The monitor-collector subelement configures the communication monitor/Palladion Mediation endpoints.
Parameters
- address
- IP address to push collected data to.
- port
- Port at which operations monitor server listens.
- network-interface
- Local network-interface to use for the connection.
If configuring with a media interface, that interface must belong to a configured realm.Path
monitor-collector is a subelement under the system-config element. The full path from the topmost ACLI prompt is:
