data-flow
The data-flow configuration element specifies pass-through data-traffic processing when using IKE.
Parameters
- name
- Specify the name of this instance of the data-flow configuration element.
- realm-id
- Specify the realm that supports the upstream (core side) data-flow.
- group-size
Specify the maximum number of user elements grouped together by this data-flow instance. For maximum efficiency, this value should be set to a power of 2.
- Default: 128
- Values: 2 | 4 | 8 | 16 | 32 | 64 | 128 | 256
The optional group-size parameter specifies the divisor used by this data-flow instance to segment the total address pool into smaller, individually-policed segments.
- upstream-rate
- Specify the allocated upstream bandwidth.
- Default: 0 (allocates all available bandwidth)
- Values: Min: 0 / Max: 4294967295
- downstream-rate
- Specify the allocated downstream (access side) bandwidth.
- Default: 0 (unlimited, no bandwidth restrictions)
Path
Data-flow is a subelement under the ike element. The full path from the topmost ACLI prompt is..
This is a multiple instance configuration element.
