diameter-manipulation
The diameter-manipulation configuration element defines the message manipulation elements.
Parameters
- name
- Configured name of this diameter manipulation. This is the key field.
- Default: empty
- Values: 24 character string, no special characters with the exception of the underscore and hyphen characters. Do not start name with numeric character.
- description
- Textual description of this diameter manipulation.
- Default: empty
- Values: 256 character string
- diameter-manip-rule
- Access the diameter-manip-rule subelement.
Path
diameter-manipulation is an element in the session-router path. The full path from the topmost ACLI prompt is:
