diameter-manipulation > diameter-manip-rule
The diameter-manip-rule defines an individual step in creating REGEX type message manipulation object.
Parameters
- name
- Configured name of this manipulation rule. This is the key field.
- Default: empty
- Values: Character string, no special characters with the exception of the underscore characters. Do not start name with numeric character.
- avp-code
- AVP in the Diameter message to be of manipulated by this rule. This parameter must be configured.
- Default: 0
- Values: Valid AVP code
- descr-avp-code
- Description of AVP code to be manipulated.
- Default: empty
- Values: 256 character string
- avp-type
- The data type of the content of the field the system PD is parsing to perform a manipulation on. This parameter must be configured with an enumerated value. Refer to the Diameter standards document for the encodings of individual AVPs.
- Default: none
- Values: none | octet-string | octet-hex | integer32 | unsignedint32 | address | diameteruri | enumerated
- action
- Type of manipulation action to perform on this AVP.
- Default: none
- Values: none | add | delete | store | diameter-manip | group-manip | find-replace-all | replace
- comparison-type
- Select the comparison type that the match-value uses.
- Default: case-sensitive
- Values: case-sensitive | case-insensitive | pattern-rule | boolean
- msg-type
- The message type to which this Diameter manipulation rule applies.
- Default: any
- Values:
- any—Both Requests and Reply messages
- request—Request messages only
- reply— Reply messages only
- msg-cmd-code
- The Diameter message code that this rule applies to. This parameter must be configured or the manipulation can not be applied to any message.
- Default: 0
- Values: Valid Diameter message code
- match-value
- Enter the exact value to be matched. The action you specify is only performed if the header value matches. The entered value must match the comparison type.
- Default: empty
- new-value
- The explicit value for a new element or replacement value for an existing element. You can enter an expression that includes a combination of absolute values, pre-defined parameters, and operators.
- Default: empty
- avp-header-rule
- Access the avp-header-rule subelement.
Path
diameter-manip-rule is a subelement under the diameter-manipulation element in the session-router path. The full path from the topmost ACLI prompt is:
