diameter-manipulation > diameter-manip-rule > avp-header-rule
The avp-header-rule subelement defines how to manipulate an AVP's header.
Parameters
- name
- Configured name of this AVP header rule. This is the key field.
- Default: empty
- Values: Character string, no special characters with the exception of the underscore characters. Do not start name with numeric character.
- header-type
- Type of AVP header to manipulate, as either the AVP flags or the Vendor ID.
- Default: avp-flags
- Values: avp-flags | avp-vendor-id
- action
- Type of manipulation action to perform on data range in the AVP header.
- Default: none
- Values: none | add | delete | replace
- match-value
- Value to be matched in the AVP flags or in the vendor ID bits. When manipulating AVP flags, the enumerated values are used to indicate which flag. When manipulating the vendor ID, an integer is entered.
- Default: empty
- Values: vendor | must | proxy
- new-value
- value to replace the match value with. You can enter an expression that includes a combination of absolute values, pre-defined parameters, and operators.
- Default: empty
Path
avp-header-rule is a subelement under the session-router path. The full path from the topmost ACLI prompt is:
