dnsalg-constraints
The dnsalg-constraints configuration element is used to provision various traffic constraints upon existing dns-config configurations.
Parameters
- name
- name of the dnsalg constraint configuration element this value is applied in a dns-config configuration element.
- state
- State of this dnsalg-constraint.
- Default: enabled
- Values: enabled | disabled
- max-burst-rate
- Maximum number of messages that can pass through the system in the burst rate window before setting the element to Constraints Exceeded.
- max-inbound-busrt-rate
- maximum number of inbound messages received by the referencing element within the burst rate window before setting the element to Constraint Exceeded.
- Default: 0
- Values: 0-999999
- max-outbound-burst-rate
- maximum number of outbound messages forwarded from the referencing element within the burst rate window before setting the element to Constraints Exceeded.
- Default: 0
- Values: 0-999999
- burst-rate-window
- Number of seconds during which to count messages toward a maximum burst rate.
- Default: 0
- Values: 0-999999
- max-sustain-rate
- maximum number od messages that can pass through the system in the sustained rate window before setting the element to Constraints Exceeded.
- Default: 0
- Values: 0-999999
- max-inbound-sustain-rate
- maximum number of inbound messages received by the referencing element within the sustained rate before setting the element to Constraints Exceeded.
- Default: 0
- Values: 0-999999
- max-outbound-sustain-rate
- maximum number of outbound messages forwarded from the referencing element within the sustained rate window before setting the element to Constraints Exceeded.
- Default: 0
- Values: 0-999999
- sustain-rate-window
number of seconds during which to count messages toward a maximum sustained rate. a maximum sustained rate.
- Default: 0
- Values: 0-999999
- max-latency
The maximum time in seconds a reply to a DNS request can take before considering that DNS server as out of service.
- Default: 0
- Values: 0-999999
- time-to-resume
number of seconds that the referencing element stays in Constraints Exceeded state and rejects messages before it returns to service.
- Default: 0
- Values: 0-999999
Path
Path: dnsalg-constraintsis a configuration element under the media-managerpath. The full path from the topmost ACLI prompt is: full path from the topmost ACLI prompt is: configure terminal > media-manager > dnsalg-constraints.
