dns-config
The dns-config configuration element configures the DNS-ALG on a per-client realm basis.
Parameters
- client-realm
- Enter the realm from which DNS queries are received. This value is the name of a configured realm.
- description
- Describe the dns-alg configuration element
- extra-dnsalg-stats
- Enables tracking of extra DNS ALG statistics.
- Default: enabled
- enabled | disabled
- dns-max-ttl
- Specifies the maximum DNS time to live value to support the DNS ALG feature.
- Default: 86400 seconds (24 hours)
- minimum: 30
- maximum: 2073600
- server-dns-attributes
- Enter the server-dns-attributes subelement .
- constraint-name
- Name of the dnsalg-constraints configuration element to apply to this dns-config.
- client-address-list
- Enter the IP client realm address(es) from which the Oracle Communications Session Border Controller can receive DNS queries. This field is required.
Path
dns-config is a subelement under the media-manager path. The full path from the topmost ACLI prompt is:Note:
This is a multiple instance configuration element.
