dns-config > server-dns-attributes
The server-dns-attributes subelement configures DNS servers.
Parameters
- server-realm
- Enter the realm from which DNS responses are sent. This value must be the name of a configured realm. This value is required.
- domain-suffix
- Enter the domain suffixes for which this DNS server attribute list is used. This field is required, and can start with an asterisk or a period.
- server-address-list
- Enter a list of DNS server IP addresses used for the specified domains. This field is required, and can include multiple entries.
- source-address
- Enter the source IP address from which the ALG sends queries to the DNS server (i.e., a layer 3/layer 4 source address). This field is required.
- source-port
- Enter the UDP port number from which the ALG sense queries to the DNS server (i.e., layer 3/layer 4 source address). This value is required.
- Default: 53
- Values: 1025-65535
- transaction-timeout
- Enter the number of seconds that the ALG maintains information to map a DNS server response to the appropriate client request. This value is required.
- Default: 10 seconds
- Values: Min: 0 / Max: 999999999
- address-translation
- Access the address-translation subelement
Path
server-dns-attributes is a subelement under the dns-config element. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
