policy-group > policy-agent
The policy-agent is used for configuring the members of the associated policy-group, which provides load balancing for Rx interface traffic within the RACF context on the Oracle Communications Session Border Controller.
Parameters
- name
- Specifies the name of this policy agent configuration.
- state
- Enables or
disables the operational state of this policy agent configuration.
- Default: enabled
- Values: enabled | disabled
- address
- Specifies the IP address or FQDN of the policy agent.
- port
- Specifies the port
on which the policy agent connects.
- Default: 80
- Values: Valid Range: 0-65535
- realm
- Specifies the realm where the policy-agent exists.
- watch-dog-ka-timer
- Specifies the
watchdog timer interval for this agent in seconds.
- Default: 0
- transport-protocol
- Specifies the
transport protocol used to connect to this policy-agent.
- Default: TCP
- Values: TCP / SCTP
- local-multi-home-addrs
- Applies to SCTP. Enter an IP address that is local to the OCSBC and can be used by this external policy server as an alternate connection point. This address must be the same type as the address parameter, either IPv4 or IPv6.
- remote-multi-home-addrs
- Applies to SCTP. Enter an IP addresses that can be used by this OCSBC as an alternate connection point. This address must be the same type as the address parameter, either IPv4 or IPv6.
- sctp-send-mode
- Applies to SCTP. Specifies the SCTP delivery mode. The default
value is
ordered. Valid
values are:
- ordered (Default)
- unordered
Path
policy-agent is a sub-element under the policy-group . The full path from the topmost ACLI prompt is: .
