policy-group
The policy-group is used for configuring load balancing for Rx interface traffic on the Oracle Communications Session Border Controller.
Parameters
- group-name
- Enter the name of this policy-group configuration.
- description
- Enter a description of this group name. Multi-word descriptions must be enclosed in quotes.
- state
- Enable or disable
the operational state of this policy-group configuration.
- Default: enabled
- Values: enabled | disabled
- policy-agent
- Enter the policy-agent sub-element to configure one or more policy-agents for this group. There is no limit to the number of agents you can configure.
- strategy
- Enter the policy
allocation strategy you want to use. The strategy you choose defines the order
the
OCSBC uses to try
policy-agents. The
default value is
RoundRobin. The
valid values are:
- Default: RoundRobin
- max-recursions
- Enter an integer to specify the number of times the OCSBC can recurse through the agent list.
- stop-recurse
- Enter the list of SIP response codes that terminate recursion within the group. Upon receiving one of the specified response codes, such as 401 unauthorized, or upon generating one of the specified response codes internally, such as 408 timeout, the OCSBC returns a final diameter response code to the policy-agents in the group and stops trying to route the message.
- recursion-timeout
- Time in seconds that the OCSBC waits for max-recursions to finish before timing out. The default is 15 seconds.
Path
policy-group is an element under the media-manager path. The full path from the topmost ACLI prompt is: .
