public-key
The public-key configuration element is used to generate an SSH public key to authenticate SSH sessions.
Parameters
Path
public-keyis an element under the security path. The full path from the topmost ACLI prompt is: configure terminal > security > public-key
This is a multiple instance configuration element.
