PreviousNextJavaScript must be enabled to correctly display this content
q850-sip-map
The q850-sip-map configuration element is used to map q850 cause codes to SIP response codes.
Parameters
entries
Enter the entries configuration subelement
delete
Delete a q850 to SIP mapping. Enter the q850 code.
edit
Edit a response map by number
Path
q850-sip-map is an element under the session-router path. The full path from the topmost ACLI prompt is:
configure terminal
> session-router
> q850-sip-map.
