PreviousNextJavaScript must be enabled to correctly display this content
q850-sip-map > entries
The entries subelement is used to create the mapping of q850 cause to SIP reason code.
Parameters
q850-cause
Enter the q850 cause code to map to a SIP reason code
sip-status
Enter the SIP response code that maps to this q850 cause code
Values: Min: 100 | Max: 699
sip-reason
Describe the mapped SIP response code
Path
entries is a subelement under the
q850-sip-map configuration element, which is located under the session-router path. The full path from the topmost ACLI prompt is:
configure terminal
> session-router
> q850-sip-map
> entries.
