network-interface > gw-heartbeat
The gw-heartbeat subelement supports the front interface link failure detection and polling feature.
Parameters
- state
- Enable or disable front interface link detection and polling functionality on the
Oracle Communications Session Border Controller for this network-interface element
- Default: enabled
- Values: enabled | disabled
- heartbeat
- Enter the time interval in seconds between heartbeats for the front interface gateway
- Default: 0
- Values: Min: 0 | Max: 65535
- retry-count
- Enter the number of front interface gateway heartbeat retries before a gateway is considered unreachable
- Default: 0
- retry-timeout
- Enter the heartbeat retry timeout value in seconds
- Default: 1
- Values: Min: 1 | Max: 65535
- health-score
- Enter the amount to subtract from the health score if the front interface gateway heartbeat fails (i.e., expires). The health score will be decremented by the amount set in this field if the timeout value set in the gw-heartbeat: retry-timeout field is exceeded without the front interface gateway sending a response.
- Default: 0
- Values: Min: 0 | Max: 100
Path
gw-heartbeat is a subelement of the network-interface element. The full path from the topmost ACLI prompt is:
The values configured in the fields of a gw-heartbeat subelement apply to the Oracle Communications Session Border Controller on a per-network-interface basis, and can override the values configured in the redundancy element’s corresponding front interface link detection and polling fields. This is a single instance configuration subelement.
