network-interface
The network-interface element creates and configures a logical network interface.
Parameters
- name
- Enter the name of the physical interface with which this network-interface element is linked. Network-interface elements that correspond to phy-interface elements with an operation type of Control or Maintenance must start with “wancom.”
- sub-port-id
- Enter the identification of a specific virtual interface in a physical interface (e.g., a VLAN tag). A value of 0 indicates that this element is not using a virtual interface. The sub-port-id field value is only required if the operation type is Media.
- Default: 0
- Values: Min: 0 | Max: 4095
- description
- Enter a brief description of this network interface
- hostname
- Enter the hostname of this network interface. This is an optional entry that must follow FQDN Format or IP Address Format.
- ip-address
- Enter the IP address of this network interface. This is a required entry that must follow the IP Address Format.
- pri-utility-addr
- Enter the utility IP address for the primary HA peer in an HA architecture
- sec-utility-addr
- Enter the utility IP address for the secondary Oracle Communications Session Border Controller peer in an HA architecture
- netmask
- Enter the netmask portion of the IP address for this network interface entered in IP address format. The network-interface element will not function properly unless this field value is valid.
- gateway
- Enter the gateway this network interface uses to forward packets. Entries in this field must follow the IP Address Format. No packets are forwarded if this value is 0.0.0.0.
- sec-gateway
- Enter the gateway to use on the secondary Oracle Communications Session Border Controller in an HA pair. Entries in this field must follow the IP address format.
- gw-heartbeat
- Access the gateway-heartbeat subelement
- dns-ip-primary
- Enter the IP address of the primary DNS to be used for this interface
- dns-ip-backup1
- Enter the IP address of the first backup DNS to be used for this interface
- dns-ip-backup2
- Enter the IP address of the second backup DNS to be used for this interface
- dns-domain
- Set the default domain name used to populate incomplete hostnames that do not include a domain. Entries must follow the Name Format.
- dns-timeout
- Enter the total time in seconds you want to elapse before a query (and its retransmissions) sent to a DNS server timeout
- Default: 11
- Values: Min: 1/ Max: 999999999
- dns-max-ttl
- Specifies the maximum DNS time to live value for this network interface.
- Default: 86400 seconds (24 hours)
- minimum: 30
- maximum: 2073600
- add-hip-ip
- Enter a list of IP addresses allowed to access signaling and maintenance protocol stacks via this front interface using the HIP feature
- remove-hip-ip
- Remove an IP address added using the add-hip-ip parameter
- add-ftp-ip
- This parameter has been deprecated
- remove-ftp-ip
- add-icmp-ip
- Enter a list of IP addresses from which ICMP traffic can be received and acted upon by a front media interface
- remove-icmp-ip
- Remove an IP address added using the add-icmp-ip parameter
- add-snmp-ip
- Enter a list of IP addresses from which SNMP traffic can be received and acted upon by a front media interface
- remove-snmp-ip
- Remove an IP address added using the add-snmp-ip parameter
- add-telnet-ip
- remove-telnet-ip
- add-ssh-ip
- Enter a list of IP addresses from which SSH traffic can be received and acted upon by a front media interface.
- Default: None
- Values: A valid IPv4 network address
- signaling-mtu
- MTU size for packets leaving this interface.
- Default: inherits system wide MTU
- Values:
- IPv4: <0, 576-4096>
- IPv6: <0, 1280-4096
Path
The full path from the topmost ACLI prompt is:
This is a multiple instance configuration subelement.
