net-management-control
The net-management-control configuration element allows you to control multimedia traffic, specifically for static call gapping and 911 exception handling. These controls limit the volume or rate of traffic for a specific set of dialed numbers or dialed-number prefixes.
Parameters
- name
- Enter the name of this network management control rule.
- state
- Select the state of this network management control rule.
- Default: enabled
- Values: enabled | disabled
- type
- Enter the control type you want to use.
- Values: GAP-RATE | GAP-PERCENT | PRIORITY
- value
- Enter the control value of the net management control. This parameter applies only when you set the control type to either GAP-RATE or GAP-PERCENT.
- Default: 0
- Values: GAP-RATE: 0-2147483647 | GAP-PERCENTAGE: 0-100
- Treatment
- Enter the treatment method you want to use or leave this parameter set toNONE
- Values: REJECT | DIVERT
- next-hop
- Enter the next hop for the
Oracle Communications Session Border Controller to use when the treatment method is DIVERT. This value should contain one of the following:
- hostname(:port) or IPv4 address or IPv6 address of a configured session agent.
- IPv4 address (:port) or IPv6 address (:port) of a specific endpoint
- realm-next-hop
- Enter the realm identifier to designate the realm of the next hop when the treatment type is DIVERT
- protocol-next-hop
- Enter the signaling protocol for the next hop when the treatment type is DIVERT
- status-code
- Enter the SIP response code that you want the
Oracle Communications Session Border Controller to use when the treatment method is REJECT
- Default: 503
- Values: Min: 1 / Max: 699
- cause-code
- Enter the Q.850 cause code that you want the
- Default: 63
- Values: Min: 1 / Max: 999999999
- gap-rate-max-count
- Enter the maximum token counter value for gapping rate
- Default: 0
- Values: Min: 0 / Max: 999999999
- gap-rate-window-size
- Enter the window size (in seconds) for gapping rate calculation
- Default: 0
- destination-identifier
- Enter the classification key. This parameter specifies information about the destination, which can be an IP address, an FQDN, and destination (called) number, or destination prefix. You can wildcard characters in the classification key using the carat symbol (^).
This parameter can accommodate a list of entries so that, if necessary, you can specify multiple classification keys.
- add-destination-identifier
- Add a destination identifier
- remove-destination-identifier
- Remove a destination identifier
- rph-feature
- Set the state of NSEP support for this NMC rule
- Default: disabled
- rph-profile
- Enter the name of the RPH profile to apply to this NMC rule
- Default: None
- Values: Name of an rph-profile
- rph-policy
- Enter the name of the RPH policy to apply to this NMC rule
- Default: None
- Values: Name of an rph-policy
- sip-380-reason
- Adds configurable reason for IR.92 Multiple Emergency Numbers feature
- Default: None
- Values: Enter a reason phrase enclosed in quotes
Path
net-management-control is an element of the session-router path. The full path from the topmost ACLI prompt is:
