system-config > directory-cleanup
The syslog-servers subelement configures multiple syslog servers.
Parameters
- directory-path
- name of the directory path where you want the Oracle Communications Session Border Controller to perform file clean-up. Subdirectories are not examined or cleaned, they must be explicitly identified.
- admin-state
- State of cleanup for this directory.
- Default: enabled
- Values: enabled | disabled
- age
- age in number of days after which to delete files in this directory
Path
directory-cleanup is a subelement under the system-config element. The full path from the topmost ACLI prompt is:
