system-config > syslog-servers
The syslog-servers subelement configures multiple syslog servers.
Parameters
- address
- Enter the syslog server’s IP address. This is configurable with an IPv4 or IPv6 address.
- port
- Enter the port number on the syslog server that the
Oracle Communications Session Border Controller sends log
- Default 514
- facility
- Enter the user-defined facility value sent in every syslog message from the
Oracle Communications Session Border Controller to the syslog server. This value must conform to IETF RFC 3164.
- Default 4
Path
syslog-servers is a subelement under the system-config element. The full path from the topmost ACLI prompt is:
We recommend configuring no more than 8 syslog-config subelements. This is a multiple instance configuration subelement.
