system-config > collect > group-settings
The group-settings subelement allows you to configure and modify collection parameters for specific groups.
Parameters
- group-name
- Enter the name of
the object the configuration parameters are for. There can only be one object
per group.
- Values:
- dnsalg-rate - DNS-ALG rate
- dnsalg-rate-per-addr - DNS-ALG rate per addr
- dnsalg-rate-per-realm - DNS-ALG rate per realm
- enum-rate - ENUM rate
- enum-rate-per-addr - ENUM rate per addr
- enum-rate-per-name - Request action in the ENUM rate per name
- enum-stats - ENUM stats
- ext-rx-policy-server - external Rx Policy Server group
- fan - fan group
- h323-stats - H323 Statistics group
- interface - interface group
- network-util - network utilization group
- registration-realm - registration realm group
- sa-imsaka - Request action on Security Associations for IMS-AKA group. Only Supported for Enterprise Products.
- sa-srtp - Request action on Security Associations for SRTP group
- session-agent - session agent group
- session-realm - session realm group
- sip-ACL-oper - SIP ACL Operations group
- sip-ACL-status - SIP ACL Status group
- sip-agent-method - SIP methods on the session agent
- sip-client - SIP Client Transaction group
- sip-codec-per-realm - SIP codecs per realm group
- sip-errors - SIP Errors/Events group
- sip-interface-method - SIP methods on the interface
- sip-invites - SIP Invites
- sip-method - SIP methods
- sip-policy - SIP Policy/Routing group
- sip-rate - SIP rate
- sip-rate-per-agent - SIP rate per agent
- sip-rate-per-inf - SIP rate per interface
- sip-realm-method - SIP methods on the realm
- sip-server - SIP Server Transaction group
- sip-sessions - SIP Session Status group
- sip-srvcc - SIP SRVCC group. Only Supported for Enterprise Products.
- sip-status - SIP Status group
- sobjects - sobjects group
- space - space group
- survivability-sip-errors - Survivability SIP Errors/Events group. Only Supported for Enterprise Products.
- survivability-sip-invites - Survivability SIP Invites. Only Supported for Enterprise Products.
- survivability-sip-registration - Survivability SIP Registrations. Only Supported for Enterprise Products.
- survivability-sip-status - Survivability SIP Status group. Only Supported for Enterprise Products.
- system - system group
- temperature - temperature group
- thread-event - thread event group
- thread-usage - thread usage group
- tscf-stats - tscf-stats group
- voltage - voltage group
- xcode-codec-util - Transcoding Codec Utilization group
- xcode-session-gen-info - general info about transcoding sessions
- xcode-tcm-util - Transcoding TCM Utilization group
- Values:
- sample-interval
- Enter the group
data collection sampling interval, in minutes
- Default: 0
- Values: Min: 0 / Max: 120
- start-time
- Enter the date and time to start group data collection. Enter in the form of: yyyy-mm-dd-hh:mm:ss (y=year; m=month; d=day; h=hour; m=minute; s=second)
- end-time
- Enter the date and time to stop group data collection. Enter in the form of: yyyy-mm-dd-hh:mm:ss (y=year; m=month; d=day; h=hour; m=minute; s=second)
- boot-state
- Enable or disable
data collection for this group.
- Default: disabled
- Values: enabled | disabled
Path
group-settings is a subelement of the configure terminal > system > system-config > collect > subelement. The full path from the topmost ACLI prompt is: configure terminal > system > system-config > collect > group-settings
