system-config > collect > push-receiver
The push-receiver configuration subelement allows you to configure the Oracle Communications Session Border Controller to push collected data to a specified node.
Parameters
- address
- Enter the hostname or IP address to which the Oracle Communications Session Border Controller pushes collected data
- user-name
- password
- Enter the login password for the specified server used when pushing collected data
- data-store
- Enter a directory on the specified server in which to put collected data
- protocol
- Set the protocol with which to send HDR collection record files.
- Default FTP
- Values FTP | SFTP
Path
push-receiver is a subelement of the system-config>collect subelement. The full path from the topmost ACLI prompt is: configure terminal > system > system-config > collect > push-receiver.
