debug-disable
The debug-disable command removes access to the shell, control, and lshell commands.
Executing this command prompts you to enter the password you set when you executed the debug-enable command. After entering that password, access to the shell, control, and lshell commands is unavailable.
Syntax
debug-disable
Mode
Superuser
