debug-enable
The debug-enable command is used to enable access to the shell, control, and lshell commands by setting a single password that provides authorization to executing them.
This command enables and sets the password used to access the shell, control, and lshell commands. Until debug password is set, you may not access the three debug commands.
To remove access to the three debug commands, use the debug-disable command. You will be prompted for the previously configured password you set by using debug-enable.
If you use the debug-enable command to set a debug password, and revert to a previous version of Oracle Communications Session Border Controller, the password set here is used to access the shell (or similar) command for earlier versions.
Syntax
debug-enable
Mode
Superuser
