delete realm-specifics
The delete realm-specifics command used with a realm identifier deletes the specified realm, and its configuration objects. This command should be used with the utmost care.
Syntax
delete realm-specifics <realm identifier>
Arguments
- <realm identifier>—Enter the identifier for the realm you want to delete
Mode
Superuser (in addition, you need to be in configuration mode)
Example
ORACLE(configure)# delete realm-specifics peer_1
