delete-backup-config
The delete-backup-config command deletes a saved configuration file from the Oracle Communications Session Border Controller flash memory.
Syntax
delete-backup-config <backup-name>
Arguments
- <backup-name> - Enter the name of the backup configuration you want to delete
Mode
Superuser
Example
ORACLE#delete-backup-config JAN_BACKUP.gz
Use display-backups to list backup configurations to delete.
