delete-config
The delete-config command deletes the current configuration located in the /code/data and /code/config directories from the system’s flash memory.
Syntax
delete-config [cached]
Arguments
- [cached] Delete the cached configuration. This is an optional argument.
Mode
Superuser
Example
ORACLE# delete-config
When the delete-config command is entered, the system gives the warning asking if you really want to erase either the current config or the current cached config. Enter a y to complete the deletion.
