enable
The enable command changes the current ACLI session from User mode to Superuser mode.
Syntax
enable
Arguments
none
Mode
User
Example
Observing the command prompt can tell you if the Oracle Communications Session Border Controller is in user or superuser mode. A ">" (close-angle-bracket) indicates User mode and a "#" (pound) sign indicates Superuser mode.ORACLE> enable ORACLE#
