display-running-cfg-version
The display-running-cfg-version command displays the current configuration version.
Syntax
Arguments
none
Mode
User
Example
ORACLE# display-running-cfg-version
This command displays the version number of the running configuration, an integer value that is incremented by one for each new configuration version.
