authentication > radius-servers
The radius-servers subelement defines and configures the RADIUS servers that the Oracle Communications Session Border Controller communicates with.
Parameters
- address
- Enter the IP address for the RADIUS server. An IPv4 or IPv6 address is valid for this parameter.
- port
- Enter the port number on the remote IP address for the RADIUS server
- Default: 1812
- Values: 1645 | 1812
- state
- Enable or disable this configured RADIUS server
- Default: enabled
- Values: enabled | disabled
- secret
- Enter the password the RADIUS server and the Oracle Communications Session Border Controller share. This password is not transmitted between the two when the request for authentication is initiated.
- nas-id
- Enter the NAS ID for the RADIUS server
- realm-id
- Enter the RADIUS server realm ID.
- retry-limit
- Set the number of times the
Oracle Communications Session Border Controller retries to authenticate with this RADIUS server
- Default: 3
- Values: Min: 1 / Max: 5
- retry-time
- Enter the time in seconds the
Oracle Communications Session Border Controller waits before retrying to authenticate with this RADIUS server
- Default: 5
- Values: Min: 5 / Max: 10
- maximum-sessions
- Enter the maximum number of sessions to maintain with this RADIUS server
- Default: 255
- Values: Min: 1 / Max: 255
- class
- Select the class of this RADIUS server as either primary or secondary. A connection to the primary server is tried before a connection to the secondary server is tried.
- Default: primary
- Values: primary | secondary
- dead-time
- Set the time in seconds before the
Oracle Communications Session Border Controller retries a RADIUS server that it has designated as dead
- Default: 10
- Values: Min: 10 / Max: 10000
- authentication-methods
- Select the authentication method the
Oracle Communications Session Border Controller uses when communicating with the RADIUS server
- Default: pap
- Values: all | pap | chap | mschapv2
Path
radius-servers is a subelement under the authentication configuration element under the security path. The full path from the topmost prompt is:
