authentication > tacacs-servers
The tacacs-servers subelement defines and configures the TACACS+ servers that the Oracle Communications Session Border Controller communicates with.
Parameters
- address
- Enter the IP address for the TACACS server. This address must be reachable over the system's media interfaces.
- port
- Enter the port number on the remote IP address for the TACACS server
- Default: 49
- Values: 1645 | 1812
- state
- Enable or disable this configured TACACS server
- Default: enabled
- Values: enabled | disabled
- secret
- Enter the password the TACACS server and the Oracle Communications Session Border Controller share. This password is not transmitted between the two when the request for authentication is initiated.
- realm-id
- Enter the TACACS server realm ID. This realm must be reachable from the system's media interfaces.
- dead-time
- Set the time in seconds before the
Oracle Communications Session Border Controller retries a TACACS server that it has designated as dead
- Default: 10
- Values: Min: 10 / Max: 10000
- authentication-methods
- Select the authentication method the
Oracle Communications Session Border Controller uses when communicating with the TACACS server
- Default: pap
- Values: all | pap | chap | ascii
- tacas-authorization-arg-mode
- Enable to allow TACACS+ Authorization Command and Arguments Boundary feature.
- Default: disabled
Path
tacacs-servers is a subelement under the authentication configuration element under the security path. The full path from the topmost prompt is:
