load image
The load image command guides users through the upgrade process, thereby keeping errors to a minimum.
Syntax
load image <IP address> <filename> <username>
Arguments
<IP address> Enter the IP address of the remote host
<filename> Enter the remote filename with path
<username> Enter the username for the remote host
Mode
Superuser
You can either enter these arguments all in one line (with a <Space> between each), or you can press <Enter> after each entry to move to the next piece of information required to load the new information.Once you have entered all of the required information, you will be prompted for the password for the remote host and the image loading process starts.
Example
ORACLE# load image 192.30.8.50 /image/nnC511p4.gz user
