interface-mapping
The interface-mapping command manages interfaces via MAC address to Oracle Communications Session Border Controller physical interface configuration name mapping. The element includes configuration and management controls. This element is applicable only to COTs and VM deployments; the software recognizes hardware platform during installation and makes the interface-mapping command available only with applicable platforms.
Parameters
- show
- Allows the user to display a table that shows the current mapping between interface MAC addresses and physical interface configuration names. The output of this command is the same as the show interface-mapping command.
- locate <ethernet if name> <seconds>
- Allows the user to cause the system to blink the LEDs associated with the specified ethernet interface name for the specified number of seconds. This command allows the user to physically identify an interface based on its interface name. This command is not applicable to virtual machine deployments.
- label <ethernet if name> <labeling text>
- Allows the user to specify a label used in the mapping table displayed using the interface-mapping show command.
- delete <ethernet if name>
- Allows the user to remove the specified mapping from the interface-mapping show table. The user cannot use a deleted interface within the Oracle Communications Session Border Controller's configuration.
- swap <ethernet if name1> <ethernet if name2>
- Allows the user to change the current interface mapping by swapping the specified interface names between each other.
Path
interface-mapping is a command (and branch) at the root path, and is only visible on COTS and VM platform deployments.
