import-certificate
For TLS support, the import-certificate command allows you to import a certificate record.
Syntax
import-certificate <type>
Arguments
- <type> - Enter the type of certificate you want to import.
- Values
- pkcs7—Import using a password enhanced mail format
- x509—Import using a password enhanced mail format
- try-all—Try importing from both pkcs7 and x509
Mode
Superuser
Example
ORACLE# import-certificate x509
