halt
The halt command prepares the platform for a clean system shutdown. This is similar to the reboot command, except the halt command does not explicitly reboot the system. The halt command (like the reboot command) may accept a force argument i.e. halt the system regardless of whether it would cause a service outage. The sysprep and exit arguments should only be used under Oracle direction.
Syntax
halt [force | sysprep | exit]
Arguments
force—Force the box halt regardless of current state.
sysprep—This command can only be run when in debug mode, and should only be used under Oracle direction.
exit—This command can only be run when in debug mode, and should only be used under Oracle direction.
Mode
Superuser
