generate-key
The generate-key command allows you to generate a security key.
Syntax
generate-key <type>
Arguments
- <type> - Select the type of key you want to generate. The following is a list of valid security keys.
- Values:
- 3des— Generate a 3DES 192 bit, odd parity key
- aes-128— Generate an AES 128 bit key
- aes-256— Generate an AES 256 bit key
- des— Generate a DES 64 bit, odd parity key
- hmac-md5— Generate an HMAC MD5 secret
- hmac-sha1— Generate an HMAC SHA1 secret
Mode
Superuser
Example 2-1 Example
ORACLE# generate-key aes-256
