generate-certificate-request
For TLS Support, the generate-certificate-request command allows you to generate a private key and a certificate request in the PKCS10 PEM format. The generated private key is stored in the certificate record configuration. If the certificate record is designed to hold a CA certificate, there is no need to generate a certificate request.
Syntax
generate-certificate-request <certificate-record-name>
Arguments
- <certificate-record-name> - Enter the name of the certificate you want to view.
Mode
Superuser
Example
ORACLE# generate-certificate-request acmepacket
