ipsec > security-policy > outbound-sa-fine-grained-mask
This configuration element allows you to configure a fine grained security policy.
Parameters
- local-ip-mask
- Enter the local IP address mask
- Default: 255.255.255.255
- remote-ip-mask
- Enter the remote IP address mask.
- local-port-mask
- Enter the local port mask for this security policy.
- Default: 0
- Values: Min: 0 / Max: 65535
- remote-port-mask
- Enter the remote port mask for this security policy.
- Default: 0
- trans-protocol-mask
- Enter the transport protocol mask for this security policy
- Default: 0
- Values: Min: 0 | Max: 255
- vlan-mask
- Enter the VLAN ID mask
- Default: 0x000
- Values: 0x000 (disabled)-0xFFF
Path
outbound-sa-fine-grained-mask is a subelement under the ipsec>security-policy element. The full path from the topmost ACLI prompt is: configure-terminal > security > ipsec > security-policy > outbound-sa-fine-grained-mask.
