iwf-config
The iwf-config element enables the H.323—SIP interworking (IWF) and provides a list of media profiles to use when IWF translations occur.
Parameters
- state
- Enable or disable the
Oracle Communications Session Border Controller’s IWF
- Default: disabled
- Values: enabled | disabled
- media-profiles
- Set the default media SDP profiles that
Oracle Communications Session Border Controller uses for Slow Start IWF calls. This field does not have a relationship with the media-profiles field found in the h323-stack subelement, as the values configured there affect calls that take place entirely in H.323. This list must be populated with the SDP codec names.
- Values: • PCMU | PCMA | G722 | G723 | G726-32 | G728 | G729 | H261 | H263
- logging
- Enable or disable IWF-related SIP messages logging
- Default: disabled
- add-reason-hdr
- Enable or disable adding the Reason header to IWF calls
- Default: disabled
Path
iwf-config is an element under the session-router path. The full path from the topmost ACLI prompt is: .
This is a single instance configuration element.
