The license configuration element is used for configuring
Oracle Communications Session Border Controller licenses.
Parameters
- add
- Add a license by entering a key obtained from your service representative.
- no
- Delete licenses by feature. You are prompted to choose a license for deletion based on license features.
Path
licenses is an element under the system-config path. The full path from the topmost ACLI prompt is:
