local-address-pool
The local-address-pool configuration element enables creation of local address pools, which can be used to provide a local (internal) address in response to remote requests for IP addresses.
Parameters
- name
- Enter a unique identifier for this local-address-pool instance.
- Default None
- Values A valid configuration element name that is unique within the local-address-pool namespace.
- address-range
- Access the address-range subelement.
- dns-realm-id
- Enter a DNS realm that supports this local-address-pool instance.
- Default: None
- Values: Name of an existing dns-realm configuration element.
- data-flow-list
- Enter a data-flow configuration element assaigned to this local-address-pool instance. This parameter specifies bandwidth availible to the pool of addresses specified by this local-address-pool instance.
- Default: None
- Values: Name of an existing data-flow configuration element local-address-pool is a subelement under the ike element. The full path from the topmost ACLI prompt is: configure>terminal>security>ike>local-address-pool.
Path
local-address-pool is a subelement under the ike element. The full path from the topmost ACLI prompt is: configure terminal > security > ike > local-address-pool
This is a multiple instance configuration element.
