local-address-pool > address-range
The address-range configuration element specifies a single range of contiguous IPv4 addresses that are available to fulfill remote requests for a local address.
Parameters
- network-address
- In conjunction with this parameter defines a range of IPv4 addresses available for dynamic assignment.
- Default: Nome
- Values: A valid IPv4 network address.
- subnet-mask
- In conjunction with network-address, the parameter defines a range of IPv4 addresses available for dynamic assignment.
- Default: None
- Values: A valid IPv4 subnet mask
Path
is a subelement under the ike element. The full path from the topmost ACLI prompt: .
This is a multiple instance configuration.
