sip-isup-profile
The sip-isup-profile element allows you to set up a SIP ISUP format interworking. You can apply a configured SIP ISUP profile to a realm, session agent or SIP interface.
Parameters
- name
- Enter a unique identifier for this SIP ISUP profile. This name is used when you apply the profile to realms, session agents, and SIP interfaces.
- isup-version
- Specify the ISUP version to which you want to convert.
- Default: ansi-2000
- Values: ansi-2000 | itu-t926 | gr-317 | etsi-356
- convert-isup-format
- Enable or disable this parameter to perform SIP ISUP format version interworking. If this feature is set to disabled, the feature is turned off.
- Default: disabled
- Values: enabled | disabled
Path
sip-isup-profile is an element under the session-router path. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-isup-profile.
This is a multiple instance configuration element.
