sip-manipulation
The sip-manipulation feature lets theOracle Communications Session Border Controller add, modify, and delete SIP headers and SIP header elements.
Parameters
- name
- Enter the name of this list of header rules.
- header-rules
- Access the header-rules subelement.
- mime-rules
- Access the mime-rules subelement.
- mime-isup-rules
- Access the mime-isup-rules-rules subelement.
- mime-sdp-rules
- Access the mime-sdp-rules-rules subelement which is used to configure HMR for SDP bodies.
- import
- Enter the complete file name, including .gz, of a previously exported sip-manipulation rule.
- export
- Enter the file name of a SIP manipulation to export configuration information a designated file.
- description
- Describe what the set of header rules is doing.
Path
sip-manipulation is an element under the session-router path. The full path from the topmost ACLI prompt is:
