sip-manipulation > header-rules
The header-rules subelement is used to define one action to perform on a given SIP header.
Parameters
- name
- Enter the name of the header to which this rule applies. This name must match a header name.
- action
- Select the action you want applied to the header specified in the name parameter.
- Default: none
- Values:
- add—Add a new header, if that header does not already exist
- delete—Delete the header, if it exists
- manipulate—Manipulate this header according to the element rules configured
- store—Store this header
- none—Take no action
- match-value
- Enter the exact value to be matched. The action you specify is only performed if the header value matches.
- msg-type
- Select the message type to which this header rule applies
- Default: any
- Values:
- any—Both Requests and Reply messages
- request—Request messages only
- reply— Reply messages only
- methods
- Enter a list of SIP methods that this header rule applies to. An empty value applies this header rule to all SIP method messages.
- Default: none
- element-rules
- Access the element rules sub-subelement
- header-name
- Enter the header name for which the rules need to be applied
- comparison-type
- Select the comparison type that the match-value uses
- Default: case-sensitive
- Values:
- case-sensitive
- case-insensitive
- pattern-rule
- refer-case-sensitive
- refer-case-insensitive
- boolean
- new-value
- The new value to be used in add or manipulate actions. To clear the new-value enter an empty string.
Path
header-rules is a subelement under the sip-manipulation configuration element, under the session-router path. The full path from the topmost ACLI prompt is:
