sip-manipulation > header-rules > element-rules
The element-rules sub-subelement is used to define a list of actions to perform on a given SIP header.
Parameters
- name
- Enter the name of the element to which this rule applies. The name parameter does not apply for the following element types: header-value, uri-user, uri-host, uri-port, uri-header. You still need to enter a dummy value here for tracking purposes.
- type
- Select the type of element on which to perform the action
- Default: none
- Values:
- header-value—Full value of the header
- header-param-name—Header parameter name
- header-param—Parameter portion of the header
- uri-display—Display of the SIP URI
- uri-user—User portion of the SIP URI
- uri-host—Host portion of the SIP URI
- uri-port—Port number portion of the SIP URI
- uri-param-name—Name of the SIP URI param
- uri-param—Parameter included in the SIP URI
- uri-header-name—SIP URI header name
- uri-header—Header included in a request constructed from the URI
- uri-user-param—User parameter of the SIP URI
- status-code—Status code of the SIP URI
- reason-phrase—Reason phrase of the SIP URI
- uri-user-only—URI username without the URI user parameters
- uri-phone-number-only—User part of the SIP/TEL URI without the user parameters when the user qualifies for specific BNF
- action
- Select the action to take to the element specified in the name
parameter, if there is a match value
- Default: none
- Values:
- none—No action taken
- add—Add a new element, if it does not already exist
- replace—Replace the elements
- delete-element—Delete the specified element, if it exists
- delete-header—Delete the specified header, if it exists
- store—Store the elements
- match-val-type
- Select the type of value that needs to be matched for the action
to be performed
- Default: ANY
- Values:
- FQDN—FQDN value
- ANY— Both IP or FQDN values
- match-value
- Enter the value to match against the element value for a manipulation action to be performed
- new-value
- Enter the explicit value for a new element or replacement value
for an existing element. You can enter an expression that includes a
combination of absolute values, pre-defined parameters, and operators.
- Use double quotes around string values
- Pre-defined
parameters always start with a $. Valid pre-defined parameters are:
- $ORIGINAL—Original value of the element is used.
- $LOCAL_IP—Local IP address is used when you receive an inbound address.
- $REMOTE_IP—Remote IP address is used.
- $REMOTE_VIA_HOST—Remote VIA host part is used.
- $TRUNK_GROUP—Trunk group is used.
- $TRUNK_GROUP_CONTEXT—Trunk group context is used.
- Operators are:
Operator Description + Append the value to the end. For example:
“acme”+”packet”
generates “acmepacket”
+^ Prepends the value. For example:
“acme”+^”packet”
generates “packetacme”
- Subtract at the end. For example:
“112311”-”11”
generates “1123”
-^ Subtract at the beginning. For example:
“112311”-^”11”
generates “2311”
- parameter-name
- Enter the element parameter name for which the rules need to be applied
- comparison-type
- Select the type of comparison to be used for the match-value
- Default: case-sensitive
- Values: case-sensitive | case-insensitive | pattern-rule
The full path from the topmost ACLI prompt is:
Path
element-rules is a sub-subelement under the header-rules subelement under the sip-manipulation configuration element, under the session-router path.
