sipura-profile
The sipura-profile element is analogous to existing sdes-profiles or IKE security associations in that all these objects specify materials (certificates, protocol suites, etc.) available in support of cryptographic operations.
Syntax
sipura-profile <name | crypto-list | certificate-file-name>
Parameters
- name
- A unique name for this sipura profile.
- crypto-list
- Cryptographic algorithm for this profile.
- Default: AES_CM_128_HMAC_MD5
- AES_CM_128_HMAC_MD5
- certificate-file-name
Required parameter to specify the file name of the minicertificate presented by the SBC in support of Linksys/sipura operations. This file must have been previously installed in the /code/sipura directory. When identifying the file, use the complete file name, to include the file extension, but omit the directory path.
Path
sipura-profile is an element of the media-security path. The full path from the topmost ACLI prompt is:
