sip-response-map > entries
The entries subelement establishes the status code(s) for both received and transmitted messages and the reason phrase(s) of a SIP response map.
Parameters
- recv-code
- Enter the original SIP response code received
				- Values: Min: 1 / Max: 699
- xmit-code
- Enter the setting of translated SIP response code transmitted
- reason
- Enter the setting of translated response comment or reason phrase to send denoted by an entry in quotation marks
- method
- Enter the SIP method name you want to use for this SIP response map entry
- register-response-expires
- Enter the time you want to use for the expires time when mapping the SIP method you identified in the method parameter. By default, the expires time is the Retry-After time (if there is one in the response) of the expires value in the Register request (if there is no Retry-After expires time). Any value you configure in this parameter (when not using the defaults) should never exceed the Register request’s expires time.
				- Values: Min: 0 / Max: 999999999
Path
entries is a subelement of the sip-response-map element. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
