PreviousNextJavaScript must be enabled to correctly display this content
sip-response-map
The sip-response-map element establishes SIP response maps associated with the upstream session agent.
Parameters
name
Name of SIP response map
entries
Access the entries subelement
delete
Remove the selected response-map entry
Path
sip-response-map is an element under the session-router path. The full path from the topmost ACLI prompt is:
configure terminal
> session-router
> sip-response-map.
This is a multiple instance configuration element.
