web-server-config
The web-server-config configuration element defines the web server parameters for the SIP Monitor and Trace web front-end. Note that this object is for Enterprise software releases only.
Parameters
- state
- The state of the SIP Monitor and Trace web GUI.
- inactivity-timeout
- Time in minutes that the GUI must have remained inactive before
it ends Web session.
- Default: 5
- Min: 0 / Max: 20
- http-state
- State of web GUI running, sending, and receiving standard,
insecure HTTP traffic.
- Default: enabled
- enabled | disabled
- http-port
- HTTP port to use to connect to the Web server.
- Default: 80
- Min: 1 / Max: 65535
- https-state
- State of web GUI running, sending, and receiving secure HTTP
traffic via the HTTPS protocol.
- Default: disabled
- https-port
- HTTPS port to use to connect to the Web server.
- Default: 443
- tls-profile
- The tls-profile name for connecting to the web GUI over TLS.
Path
web-server-config is an element under the system-config element. The full path from the topmost ACLI prompt is:
