tunnel-orig-params
The tunnel-orig-params configuration element defines a single remote IKEv2 peer.
Parameters
- name
- Enter the name of this instance of the
- Default: None
- Values: A valid configuration element name, that is unique within the tunnel-orig-params namespace
- remote-addr
- Enter the IPv4 address of a remote IKEv2 peer
- Default: None
- Values: Any valid IPv4 address
- retry-limit
- Set the number of times IKEv2 tries to initiate the tunnel. If this value is exceeded, IKEv2 abandons the initiation attempt and issues an SNMP trap.
- Default: 3
- Values: Min: 1 | Max: 5
- retry-time
- Set the interval (in seconds) between initiation attempts.
- Default: 10 seconds
- Values: Min: 5 | Max: 60
Path
tunnel-orig-params is a subelement under the ike element. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
